Motor failure in Daewo Lanos
12 years 8 months before #40287 by manual-mecanica
Motor failure at Daewo Lanos published by Manual-Mecanica
I have said now a problem with a Daewo Lanos de Gasolina 1.4
When I started in cold everything normal but after a couple of minutes the engine begins to fail as if it stays in three or two cylinders, the engine then rates and does not break well, loses power.
I have changed the spark plugs, the cables and the ignition module. But it remains the same.
Thanks anticipated
12 years 8 months before #40307 by manual-mecanica
Manual-Mecanica response on the topic motor failure in Daewo Lanos
Hello good it may be that it does not injade the gasoline well and that's why you seem that you run out of power
12 years 8 months before #40331 by manual-mecanica
Thanks for the Respuiesta, but I already solved it.
It was about cleaning the hydraulic pushers of the valves, then they ran out of oil and did not comply with their mission.
