Power loss in Ford Transit 97 TD
12 years 9 months before #40173 by manual-mecanica
Power loss in Ford Transit 97 TD published by Manual-Mecanica
Hello everyone, I wanted to tell you what happens to a Ford Transit 2.4 of the 97 td of a friend ... The symptomatology is clear, it has a loss of huge power, I tell you ... you go by putting the marches and the first journey of each march does so with loss of power but not so much and reached the second half of the journey of the march (50 km/h in 3rd, 70 km/h in 4th) You have to put the next march to raise the speed ... it has the motor failure witness.
12 years 9 months before #40193 by manual-mecanica
Manual-Mecanica Response on the lost power of Ford Transit 97 TD
Hello the Ford Transit carries an Epic model pump that carry 4 fuel control solenoids when one of them fails the following does not for the engine with the key loses half or more power unfortunately the solution is to change said pump since no spare parts are manufactured.
12 years 9 months before #40217 by manual-mecanica
Ole thank you very much, I imagine that the bomb will be quite expensive to buy it, but the van can't continue like this ... thank you very much for everything ...
12 years 8 months before #40286 by manual-mecanica
Hi Pedro I had the same van but without turbo and also had the same symptom, with the tracheteo a nut of the No. 19 that is opening the hood, just a span below the end of the windshield moon, in the center looking at her in front, can be seen with the naked eye. It is incorporated into the tube of a circuit placed on the thermacustical insulator of the cabin and when the engine is badly closed when you climb the revolutions a bit. Believe it and see what happens, luck.
Salu2 J.Klon
