Nissan e13 platinos are burned
12 years 9 months before - 12 years 9 months before #40055 by manual-mecanica
Nissan E13 platinos published by Manual-Mecanica
It is a Nissan Sunny 1.3 Motor E13, the platinos are burned, the condenser is 0.25UF I don't know if it will be fine. It will be the coil, the same was seeing that it is without resistance, which has noticed that when the platinus is opened, the spark or the very visible arch is generated. Another thing the coil cables were revealed by the positive sheet to the - Platinum and coil condenser, so change them. It helps help
Latest edition: 12 years 9 months before by .
12 years 9 months before #40058 by manual-mecanica
Manual-Mecanica Response On the subject, the Nissan E13 platinos are burned
They can see the reveals because they did not put the resistance and have that bridge, usually when the platinum is burned it is because of the resistance or opening, an eye that there are coils that have the interior resistance and not on the outside.
12 years 9 months before #40059 by manual-mecanica
I forgot the condedor is fine the original is 23 microfaradios but make sure that all components are not rabies.
12 years 9 months before #40066 by manual-mecanica
Of course, I realized that they put them badly, tomorrow I will check the coil, alternator voltage, put the resistance. The platinum and condenser are made in Japan. Although the platinum is all burned and itch the nissan does not wrinkle.
As always thanks Kikemec.
12 years 9 months before #40072 by manual-mecanica
Solved.
After making the respective measurements, the person responsible for burning the platinos: the coil, resistance 2 has a value over 17 kilohms. It changed coil and voila.
