Focus 2.0 2009 problem
12 years 9 months before #39946 by manual-mecanica
Focus 2.0 2009 problem published by Manual-Mecanica
Hello, I am new in this forum, I have a problem with a focus 2.0, the car starts well after a few minutes to fail to walk like walking in 3 cylinders.The Scaner says P02110 Motorized Maripoza. What I did is clean the maripoza the fault followed the same, probate with new spark plugs and coils that I had of another car and I did not solve all the wiring is well Motorized the same follows the fault, I delete the fault and I start a few seconds and another one comes into an emergency. The doubt of mine is that if you have to prescribe the motorized maripaz
12 years 9 months before #39955 by manual-mecanica
Manual-Mecanica Response on the problem Focus 2.0 2009
On occasions, if the butterflies or reprogrammed for their proper functioning must be formatted, testing by hand the reprogramming on some occasions opens and closes the contact about 4 times after disconnecting the battery for about thirty seconds.
12 years 9 months before #39981 by manual-mecanica
I recommend that you clean the butterfly, and supervises he had to reach it from the PCV Vench Valve
12 years 9 months before #39989 by manual-mecanica
Hello guys thank you for answering, I am quite complicated with the theme I put the originals and 4 coils of another car that is fine, the maripoza clean it and reprogram as Kikemec says that I see the PCV valve and what I did is take out the 1 zonda lamd I move the maripoza fin closed until I approach to regulate the engine and the fault leaves. Thank you boys for being on the subject thanks Sergio
12 years 9 months before #39990 by manual-mecanica
