Motor does not start, Venture '98, V6 3400 engine
17 years 4 months before #3805 by manual-mecanica
Disconnect the coils and spark plug cables to disassemble the full admission multiple and correlate a problem, when we put together and connect the spark plug cables according to the order indicated in the terminals of the coils, I wanted to start the engine, and I do not do it !!!!
What could have happened? Do not the cables connect in that order?
The truck is American, it is a chocolate.
The cylinders on the side of the fire wall are: 1, 3 and 5.
The cylinders of the radiator are: 2, 4 and 6.
: Ohmy: : HUH: : Blink: : S : Woohoo:
In advance, I thank you.
17 years 4 months before #3811 by manual-mecanica
First of all it arrives or the current does not arrive, then there is a firm order that is 153624 and there is another that is in regressive ordn check it in the same aspiration collector, check if you left any disconnected cable.-
17 years 4 months before #4143 by manual-mecanica
Thank you very much friend short circuit, the problem is solved with the order you provided.
Excuse friends of the forum for not having warned before.: Cheer:
