ZAFIRA MOD 2004 LIKE ESP witness
17 years 4 months before #3802 by manual-mecanica
ZAFIRA MOD 2004 LETS ESP witness published by Manual-Mecanica
Hello Messrs.
This sapphire turned on the witness after running it in rollers at the front of the car.
These are the codes that appear in my Sconer.
Existing codes:
P31511 - Description not available.
C31530 - Description not available.
P31503 - Description not available.
Pending codes:
P1130 - Description Not available.
P31570 - Description not available.
P0730 - Incorrect gear relationship 1
can help me each of them mean so that I can repair this fault.
17 years 4 months before #3815 by manual-mecanica
Manual-Mecanica Response on the Re: Zafira Mod 2004
Hello, remember that when you rotate only two uses, it turns on the ESP Proque light does not receive the signal of the other two wheels and for the switchboard it is an error code, write down all the codes and cancel vehicle. Test and let me know greetings Alfredo.-
17 years 4 months before #3832 by manual-mecanica
Thanks for your support.
I already perform this exercise weeks and does not go out.
And these codes appear to me.
The help I need is that I do not find the meaning of these codes.
17 years 4 months before #3849 by manual-mecanica
Hi Hermes VE Ala direction automecanico.com And when you can find the codes you are looking for
