Distribution Ford Focus 1.6 dci
12 years 6 months before #39510 by manual-mecanica
Distribution Ford Focus 1.6 dci published by Manual-Mecanica
Hello everyone to see if you can help me with the distribution.
Change the distribution strap check the tensioner and the roller guide, also the water pump is in good condition all these pieces but turn the engine as a half and now makes a strange noise as if something is touch Nothing is fine.
Thank you all
12 years 6 months before #39521 by manual-mecanica
Manual-Mecanica Response on the Distribution Ford Focus 1.6 DCI
Hello friend, if you have few kms traveled you can use it again without problems, disassemble and check everything again, but I advise you to change the water pump and the tensioner along with the guide roller, if the pump seems to be in good condition, do not forget that it already walks a lot and if you get to get to gear or lose refrigerant you have to disarm everything again and it would produce considerable damage to the engine, also when you change everything. Or hum that cost to perceive, tell us how you are doing, greetings.
12 years 6 months before #39550 by manual-mecanica
I need aseure from where it tries the noise, you have walk the vehicle without the distribution tapas to rule out the belt that pink, always with the Damper Post Obio, on occasions when turning to the other side you can damage the oil pump, but it is rare that its Eda.
12 years 6 months before #39584 by manual-mecanica
Hello again when the lids and belt distribution again I found the fault, turned the tensioning roller and the
guid It was also worried about turning the engine a little in case something else had been spoiled.
Thank you all for your help
12 years 6 months before #39594 by manual-mecanica
How good that alleged your problem happy holidays and here we are for any questions.
