consultation
13 years 1 week before #39372 by manual-mecanica
Consultation published by Manual-Mecanica
Hello everyone, my query is the following, I want to know if someone can help me in this, the topic is the mocking of the Coblelet Corsa Culta Cylinder 2007 5 doors, is it left thread? Because I wanted to remove the bolons from the cylinder lid and I wanted Second round when I wanted to continue loosening, the Abia cut to all. Now the subject is to get it ,,,, someone could give me a hand?, of course thanks in advance, greetings to all ,,,,,,
13 years 1 week before #39375 by manual-mecanica
Manual-Mecanica Response on the subject consultation
Give an ostia with a heavy hammer to each and loosen on the opposite side of the clock needles
13 years 1 week before #39376 by manual-mecanica
13 years 1 week before #39379 by manual-mecanica
They are non -inverted normal thread, loosen in the opposite direction of the clock ... loosen those that are left, and if the heads are capped better use bits and sweeps, it is easier because those screws are of one use can not install them again, they will craw to give the torque of tighter, buy new are not expensive, and they are not difficult to drill, there is no space and there is not long.
13 years 1 week before #39393 by manual-mecanica
That I know are normal turn bolts release to the left like everyone else, the best way to get it is to weld a iron and go gourning little by little on occasions with the same welding temperature release.
