Opel wind window handle 2.0 i 1991
12 years 8 months before - 12 years 8 months before #39330 by manual-mecanica
Opel wind window handle 2.0 i 1991 published by manual-mecanica
Hi Foros.
I have tried in vain to remove the handle to climb the rear window. I can't find how to take it out of it.
I need to remove the door forum to get a blow to the door.
Surely there is a simple way, but I can't find it.
Relief!!!
Thanks,
Joseph.:(
12 years 8 months before #39341 by manual-mecanica
Manual-Mecanica Response on the topic Rear window Opel Vectra 2.0 I 1991
The handles bring insurance that is like a u, it is a key to get it out to get the handle, throw the handle a little out and you can see it if you do you do with a palette screwdriver you take it out and now.
12 years 8 months before #39347 by manual-mecanica
Hi Collega, I know what is normally so, but with this handle I don't see the clip.
I have separated the door forum with a screwdriver everything I dared without breaking anything but I see neither staple nor anything else that keeps it in place.
I have also separated as much as possible the Board between the handle and the door forum but I do not see a device (staple) of clamp or anything.
Any other idea ???
Thank you.
12 years 8 months before #39387 by manual-mecanica
Look if the body cannot be disassembled to see if there is a screw in the center if there is not then it is with staple if or if you want you do not see it but it has to be it happens with a Corsa the same.
12 years 8 months before #39395 by manual-mecanica
Thanks Kikemec,
I'll take another look to see if I get it out.
Another solution would be to go to scrapping and destroy one there and see where the shots go. Greetings
