Oil leak in Tiptronic Transition, Bora 2006
13 years 2 weeks before #39308 by manual-mecanica
Oil leak in Tiptronic Transmission, Bora 2006 published by Manual-Mecanica
Hello, how about friends I have little doubts I want to see if someone can guide me,
the situation is so tell me that in a 2006 Bora with Tiptronic Transmission it has a small oil leak and my question is how difficult it is to do the service to this transmission and it is revealed or making some type of adjustment or deletion of service if it appears on the board. I thank you for your valuable information
13 years 1 week before #39334 by manual-mecanica
Cellar Automatic cash leaks is complicated since you have to disarm it and if you are not careful you will be with the valve body and spend a lot of hahaha paste, if it is for the carter of the box that you can take it out without any problem and seal, the service of the board usually indicates maintenance or service for the engine not for the box.
