Problem with my Kia Gran Sportage 1999
13 years 2 weeks before #39303 by manual-mecanica
Problem with my Kia Gran Sportage 1999 published by Manual-Mecanica
Hello, I have a problem with my Kia Grand Sportage 99, I went out derivating, I checked the main rifle and it was the fuse of 15a that had burned, I camabiated it and now, after some time it takes it to the electric change cables and now it goes out but it does not burn funeate, it is time to wait a good time to turn it away .... do you know what will be?
13 years 1 week before #39332 by manual-mecanica
Manual-Mecanica Response on the problem with my Kia Gran Sportage 1999
Friend the ideal is Checar when I do not start what element is missing, that is, if it is fuel or spark, to be able to tell you that check, now if you told us that it was the fuse that was burned it would be great, so we can help you better.
13 years 1 week before #39343 by manual-mecanica
Thank you very much, the fuse that burned was the 15 amps found in the main rifle, this fuse is that of the fuel pump, injectors, main relay, fuel pump relay.
13 years 1 week before #39386 by manual-mecanica
And now it doesn't send you fuel anymore?, send direct current to the pump to see if it works I think the pump is your problem, but check with direct current to see you leave or sound like this we discard it.
13 years 1 week before #39397 by manual-mecanica
If that apparently it was, it turns without problems. Thank you so much....
