Help with the Hyundai Excel coil of 92
12 years 6 months before #39224 by manual-mecanica
Help with the Hyundai Excel coil of 92 published by Manual-Mecanica
Hello friends I have a problem with my Hyundai Excel of 92 was failing for about 4 months this went out sporadically 1 0 2 times a month when it was heated after letting it cool a little I followed normally until yesterday that it did not turn on anymore then and the tests with the coil and it did not throw the current of the athal correct someone who knows that I can guide me please
12 years 6 months before #39234 by manual-mecanica
Manual-Mecanica response on the subject helps with the Hyundai Excel coil of 92
It does the following test identifies the positive of the coil, then you throw a direct cable of the battery positibvo to the positive of the coil and you start if it part is only problem of the ignition circuit this will say that you have to start with the contact sheet, fuse and relay ... complete........
12 years 6 months before #39270 by manual-mecanica
The current arrives as a sheet to exempt the coil should there be a food cable from the sheet to the coil as RVSMA24 says, and if you can try cone it mentions it with a battery cable, now there is usually no relay or fuses for this type of sirwy, if the test works, take out a cable from sheet to coil and ready.
12 years 6 months before #39307 by manual-mecanica
ICE what they told me and nothing was seeing on YouTube and I think it must see pulsating current in the coil to excite it, they have an idea of ​​how much voltage it can be and if the distributor has to do something thanks
12 years 6 months before #39327 by manual-mecanica
Exact that pulsating current is the one from the distributor to the coil, making it exite and leave a high tension shot to the distributor cover, what type of distributor do you have?
