ELECTROVALVUAL FOOD PUMP
12 years 11 months before #39213 by manual-mecanica
ELECTROVALVUAL FOOD PUMP PUBLISHED BY MANUAL-MANICA
Someone can tell me where the fuel supply electrovalvula is at Citroen Xara 1.9 and how the fuel filter is removed.
thank you so much
12 years 11 months before #39262 by manual-mecanica
Manual-Mecanica response on the electrovalve theme food pump
Hello, the electro valve is in the injection pump, if you look at the injection pump in the part where the injection lines to the injectors can see you can see it, there connects the cable that feeds it, if you apply current you can listen to a click.
