You eat the pneumatic ones ..
13 years 2 weeks before #39149 by manual-mecanica
Manual-mecanica response on the subject The pneumatic ones are eaten ..
If Uncle eats the front right pneumatic, the shock absorber is grabbed below with a single screw, the wheel bushing is hugging and grabs the shock absorber in the lowest part with a single screw, do you know how I tell you? And nothing had thought of with a level to take as a reference the angle of fall of the wheel that is fine, with a level of arbañil the edges of the tire, is well thought or is not worth ??? Thanks for your help Kikemec
13 years 2 weeks before #39150 by manual-mecanica
13 years 2 weeks before #39153 by manual-mecanica
Hello! It is not normal for it to eat it because yes. That is that it has any blow or an element in poor condition. For example, I would lift the wheel, and Miraria if the hose has a game. and connecting rods.
13 years 2 weeks before #39160 by manual-mecanica
It has nothing broken or with slack, this afternoon I have been harming it for a while and nothing, I have not been able to do anything, the van bought it as a second with 7 months and a few kilometers 30,000, will it have had a blow ??? By devajo the car is well how weird it has is what seems like a small stand behind the right wheel in the low of the fender, the safest thing is that it has the bent shock absorber. . .
13 years 2 weeks before #39163 by manual-mecanica
Check the suspension wheel handle, which is not damaged and the basis of the shock absorber, the sponsorship spring, including the compact where the damping base is installed, which is at the same time from its opposite ... and the tires are pairs of chance, same nomenclature and brand?
