Light between Daewoo rings
12 years 11 months before #38962 by manual-mecanica
Light between Daewoo rings published by Manual-Mecanica
Make rectify cylinders of a Daewoo Racer 1.5 block from Std to 0.50. I buy x the pistons and rings 0.50
Now my question when measuring the light between the tips in the 1st compression or fire ring remains at 0.20mm loose and 0.25mm tight. According to the manual, it tells me 0.30. With light at 0.20mm they could come to run into the tips once it is running. And it is so convenient to spend the tips of the rings a bit.
12 years 11 months before #38968 by manual-mecanica
Manual-Mecanica Answer on the Light theme between Daewoo
hahaha answers you for face but if you want I tell you again hahaha, remember that the manual is for factory measures and not for overmedies.
12 years 11 months before #38986 by manual-mecanica
Perfect, I am waiting for the connecting rod metals to assemble.
thank you
