Renault 11 Txe 3 cylinders
12 years 11 months before #38844 by manual-mecanica
Renault 11 Txe 3 cylinders published by Manual-Mecanica
Hello good! It is my first time here and consults them for my car that is a few days ago that is as if it were in 3 cylinders. I clean the spark plugs that seem to be fine and continue to work badly.
any advice ?? Because the truth is that I don't know what else to do and I don't have $$$$ for the mechanic. M,
thank you very much !!!!
12 years 11 months before #38847 by manual-mecanica
Manual-Mecanica Response on the Renault 11 Txe 3 cylinders
If it is in three cylinders, you have to check the spark plug cables, the distributor or delco lid, and rotor, as well as the state of the coil, the best way to check this problem is to isolate the problem, that is to say with the engine in progress, disconnect a cable and see how the engine works, at some point you will notice that you take out a cable and the engine is running the same as this and that is the cylinder. already discovered which one is dedicated to seeing what he lacks.
12 years 11 months before #38848 by manual-mecanica
Thank you very much for the answer and suggestion.
I do that and tell you what happened.
Greetings.
12 years 11 months before #38867 by manual-mecanica
Ok comments how it went
12 years 11 months before #38984 by manual-mecanica
also review the Servo hose, in many cases it is
the problem of the Renault 11
