Excessive electrical consumption
12 years 11 months before #38814 by manual-mecanica
Electric Excessive Consumption Published by Manual-Mecanica
Hello everyone, I would like to know if you can help me in a breakdown that I have in my car is a tdi 2.0 of 115cv of the year 2001 and it has an electrical problem when I connect the air conditioning the load of the alternator goes down to about 12v we are absolute that the alternator load is absolute The same thing has happened to someone or who knows me or who knows someone who has happened to him and you can help me greeting and thank you for attending me.
12 years 11 months before #38816 by manual-mecanica
Manual-Mecanica response on the topic Electric Excessive Consumption
Your problem should be the Czech alternator regulator the load with the car on without turning on any compounds and then Check
12 years 11 months before #38900 by manual-mecanica
It can also be a battery theme, leave the lights high on 15 minutes and look if the tension in the battery falls, if so it is because truly the battery will not be more
12 years 11 months before #38917 by manual-mecanica
Good compi, because it gives me the impression that the electro magnet of the air conditioning pulley is short. To be sure, turn on the motor of the car with the air on and check that the input cable to the air compressor pulley does not rehend, if so, the paste you have on the pulley. greetings
