Help with the Samurai rpm, they go up and down
17 years 5 months before #3754 by manual-mecanica
Help with the RPM of the Samurai JX, they are not stable accelerate up to 1300 and slowly at 400 rpm. This after the preheated stage
17 years 5 months before #3759 by manual-mecanica
Veric the operation of the Landa probe, you can try to disconnect it the vehicle enters emergency but should regulate stable at about 1000 rpm
17 years 4 months before #3773 by manual-mecanica
hi, friend. I would like to help you with your Consulate but I think it is a little more information about your problem; As if the light is turned on, with cold starts how rpm, year, cc, etc. Possibly with that data you will help several foreros that we can help you. Goodbye Forero. But answer: Dry:
17 years 4 months before #3778 by manual-mecanica
Hello, your account is electronic or mechanical?
17 years 4 months before #3800 by manual-mecanica
Hello thanks for the help
these are some general data of my car is a Samurai JX year 96 has 1300 engine is injected and has a computer at no time has been lit the pilot focus of Checkengin. Since I bought it, the former owner has been with a very accelerated march, that was very gaston of gasoline and heated the engine more if you use the double. I imagine that I was accelerated by the same mess. The only works that I have lasted since I bought it has been the minor maintenance (changes of oils, spark plugs, change of spark plug wires, probe and looked as a rradiator, general brake revision and there are even just). As the problem behaves, it is that when the engine is turned on, it has its preheated stage that is an acceleration of about 1600RPM then it is descending to its 800RPM that is its normal work march in the day of walking it in the highs of the Semaphoros begins to olilar Lar RPM is accelerated by 1200 and fall by 400 being in the high of the Semaforo. Nesty helps this problem thanks.
