Oil cooler
12 years 9 months before #38659 by manual-mecanica
Oil cooler posted by manual-mecanica
I have a problem with oil cooler in a 75CV Ford Focus Focus Focus Focus 1.8TDI.
Can anyone tell me how to cancel it?
12 years 9 months before #38663 by manual-mecanica
Manual-Mecanica response on the oil cooler
Take out the two cooling sleeves that feed and units with a tube of a similar diameter.
12 years 9 months before #38664 by manual-mecanica
Hello good, just as the partner says, to cancel it you have to join the two cuffs of the refrigerant with a tube, but whenever you do not have the problem that it is chopped and the oil is communicated with the refrigerant or invea it, if so you would have to remove the oil filter and the cooler. Picado would get oil through the nozzles that are free. I hope it helps you greetings.
12 years 9 months before #38666 by manual-mecanica
Garcia, can you put the fitro without the cooler?
Because the problem is that it is communicated and as you say if one the water sleeves suppose I would get oil through the cooler tubes.
12 years 9 months before #38669 by manual-mecanica
It is not advisable to cancel the cooler, since the engine could rise temperature.
If water passes for oil or setback, you have to see if they give it fixed in a motor radiator repair site, usually if it is fixed.
