FOD FOCUS 1.8TDDI INJECTOR PROBLEM
13 years 3 days before #38611 by manual-mecanica
FOD FOCUS 1.8TDDI Injector Problem Published by Manual-Mecanica
Hello very good, I have a problem with my Ford Focus and that is that when he heated he stops.
I have been investigating a little and the cables that go to the valvua of the pump's progress have been heated, I would like to know how that valve can be checked. Thank you
13 years 1 day before #38637 by manual-mecanica
Manual-Mecanica Response on the problem Injection pump Fod Focus 1.8TDDI
It is only possible to arrive and it has been heard if it is extended, the ideal is to disassemble the pump and send it to complete check.
12 years 11 months before #38681 by manual-mecanica
Thank you for answering, I put the contact and you get the two cables but the valve does nothing.
12 years 11 months before #38696 by manual-mecanica
The valve died then it would have to sound with the success.
12 years 11 months before #38697 by manual-mecanica
I only have a doubt, it seems to me that the cables do not carry 12 volts both if not one, but I'm not sure
