Help, my civic ex 2006, does not turn on.
13 years 5 days before #38539 by manual-mecanica
Manual-Mecanica response on the subject Help, my civic ex 2006, does not turn on.
Hello.
When turning the key, nothing is activated at all, the normal turns but does nothing at all, no noise ... is totally dead.
Thank you.
13 years 5 days before #38540 by manual-mecanica
Hello.
Thank you.
I leave my email and there I send you my phone, is going?
13 years 4 days before #38546 by manual-mecanica
I send you a diagram of your car's board and currents distribution so that it is easier to check if you need any other I leave you my email Greetings from Saltillo.
13 years 4 days before #38567 by manual-mecanica
If you do nothing at all, the first thing is Checar if when you turn the key it reaches food to the starter engine if it arrives but does nothing the starter would be the problem, if it does not reach the exitation current then it can be the contact sheet or the immobiliser that I think is the most caused if you have a coded key.
13 years 4 days before #38591 by manual-mecanica
Thank you very much Kikemec.
I suppose that if the key is coded, because these cars are like this but, how do I remove the immobilizer?
Thank you so much.
