Montero Sport 1998
13 years 1 week before #38393 by manual-mecanica
Montero Sport 1998 Published by Manual-Mecanica
Good afternoon, I would like someone to guide me with the following, I have a Montero Sport from 98 4G64 engine, I have problems with carburetion, it has low -speed failures at normal fuel, it is briefly removed and returns. Can it be dirt in injectors or oxygen problems?
13 years 1 week before #38423 by manual-mecanica
Manual-Mecanica Answer on the Montero Sport 1998
Hello, I would start by checking spark plugs and cables, which do not have dough referrals, also the admission butterfly clean it well with dirt, carbonilla, etc.
13 years 1 week before #38431 by manual-mecanica
The 4G64 is the engine that brings the mitsubishi eclipse, the relay is unstable sustenance and the revolutions lower? or just have? Listen to the escape and see if the noise is cut or continuous to shorten the search field
13 years 1 week before #38434 by manual-mecanica
just tremble, accelerate and temperate
13 years 1 week before #38436 by manual-mecanica
Do not regulate you, take out the admission body and clean it with a Duco, also clean the IAC or step step, I think it is the whole problem
