Problems with R 11.92 change box
13 years 1 week before #38370 by manual-mecanica
Problems with R 11.92 change box published by Manual-Mecanica
Hello, I wanted to know if anyone knows how to solve a problem that has been presented to me.
13 years 1 week before #38388 by manual-mecanica
Manual-Mecanica response on the subject Problems with R 11.92 change box
Hello, I think (if I remember badly) that wears rods for the forwarding lever.
Is the change lever of normal touch? ...
If it is yes, you must first check what is related to the forwarding, union and rod points.
If everything is fine, you have to disassemble the change, disassemble it. You will have the problem in one of the forks that will be grabbed.
This type of changes is not very difficult to disarm.
Cheer up.
All the best
13 years 1 week before #38421 by manual-mecanica
Hi, several similar cases have happened to me years ago (I don't know if it equals yours since it is very difficult to diagnose without seeing the problem "in situ"). Some in Renault 11, 9 and Express, the fact is that for some reason 2 marches at the same time one of them and always in common in all cases the march behind, I think I remember only the 5th entered, this was solved, it was solved by taking out the housing of the 5th and from there with an adequate hook manually driving the axes of the forks until leaving it in the dead man; I don't know if this is your case but I hope it is helpful
13 years 1 week before #38441 by manual-mecanica
Thank you, unfortunately I will have to do what I did not want, to disassemble the box .... Thank you for answering
13 years 1 week before #38442 by manual-mecanica
I will have to try, I will disassemble and see. Then I tell you to find myself, thanks for answering. (The box stopped working after leaving behind, takes out the march behind and success what I already tell you)
