Because my truck only reaches 3000 revolutions
12 years 10 months before #38125 by manual-mecanica
Because my truck only reaches 3000 revolutions published by Manual-Mecanica
Hello friends of the forum if I could help me because my L200 year 2008 truck ... only reaches revolutions in the Tacomero and I do not set the check. The scanner passed and no mistake does if they could tell me what is what ...
12 years 9 months before #38316 by manual-mecanica
Manual-Mecanica response on the subject because my truck only reaches 3000 revolutions
controls that the escape is not cloudy and that the injectors is in good condition greetings
12 years 9 months before #38317 by manual-mecanica
You have to verify the EGR valve if it is not cloudy in the scanner only if the empty sensor that is there will be the fault.
12 years 9 months before #38321 by manual-mecanica
Most likely, the escape system or the catalytical converter or the EGR is covered, this aforementioned stuck and you will see that Good Look improves
