Ford Focus Oil Light Lighting Lighting
13 years 1 week before #37970 by manual-mecanica
Ford Focus Oil Light Intermittent Lighting Published by Manual-Mecanica
I have a Focus Diesel that turns on the oil of the oil in an intermittent way, oil has, it does not raise temperature, I do a test by taking the cover of the oil with the engine on and it is seen that it spits oil.- Normally it turns on when it passes from the 110 km, intermittently, can I stop and turn it off, then I take it again to 110 and it does not turn on, can it be problem of the bulb or the oil pump? Thank you
13 years 1 week before #37979 by manual-mecanica
Manual-Mecanica response on the Ford Focus Oil Light Burning Light
Check the pump pressure, if it is good, check the sensor cable to the board, if you are good, change the oil pressure sensor.
luck
13 years 1 week before #38009 by manual-mecanica
It is the best thing you can do, make sure the precion of the pump to avoid further damage.
13 years 1 week before #38034 by manual-mecanica
That
what you should do is check the precion oil, but wing
that ignites the warning light and the strange thing is that you stop and it no longer turns on again, it can be dirt in the sieve of the pump or very used oil or dirty oil filter, pay attention when you turn on the focus if strange noises or bells are heard
13 years 1 week before #38036 by manual-mecanica
Well friend I would tell you that the fault is in the pump filter that call it a strainer, a fishing vessel, among others, there is a lot of dirt in the engine of the engine at a faster engine, the pump sucks more oil just like the dirt
