Zetec Rocam 1.6 temperature problem
12 years 8 months before #37868 by manual-mecanica
Zetec Rocam 1.6 Temperature Problem Published by Manual-Mecanica
I have a Ford Couer truck, it has a Zetec Rocam 1.6 engine. It heats too much
12 years 8 months before - 12 years 8 months before #37869 by manual-mecanica
Manual-Mecanica Response on the topic of temperature problem Zetec Rocam 1.6
did you check if the radiator is covered ????
Check ... it can be that ...
Latest edition: 12 years 8 months before by .
12 years 8 months before #37870 by manual-mecanica
or it can also be a hose
12 years 8 months before #37873 by manual-mecanica
Hello, fix the manguerite that goes to the reservoir from the portermostato usually covers in the step reduction it has, so it makes you believe that you burn.
12 years 8 months before #37875 by manual-mecanica
Czech the state of the oil that does not this mescado with water, that there is no oil in the water, that does not consume water and throw it through the exhaust and finally that it does not put comprehension in the water system, so you discard cylinder head, if everything may well be that the compu does not share it when appropriate, if that is the case you have a parallel installation and this is already
