Failure in the cutting electrovalve
12 years 10 months before #37863 by manual-mecanica
Failure in the cutting electrovalve published by Manual-Mecanica
Hello, I have a Ford Transit that when I take the contact the engine continues to turn. I think it is from the pump cutting electrovalve but I am not sure, how could I check it? And if it is from the electrovalvula, how could I fix it/replace it? Thanks for the help
12 years 10 months before #37866 by manual-mecanica
Manual-Mecanica response on the subject fails in the cutting electrovalve
Check if current comes to the Electrovalvula terminals.
If you are constantly even without contact, it can be a problem with a relay that was stuck.
And if it were without contact, it does not arrive signal, the electrovalve may be stuck.
I do not know how the electric part is, of that van ...
but they are things that can be drawn for conclusion and reviewing well you can reach the fault.
Hopefully something as a guide serves you.
Luck.
12 years 10 months before #37902 by manual-mecanica
The but the contact closes inside. (The board lights go out). If the lights on the board are on, disconnect the alternator's plug, then make it walk and stop it. If the engine stops, it means that the problem is the alternator voltage regulatory box.
I hope it serves you .....
12 years 10 months before #37904 by manual-mecanica
ole, thank you very much, I have verified what you have told me and effectively is the electrovalve
