Ford 4000
13 years 2 months before #37789 by manual-mecanica
Ford 4000 Published by manual-mecanica
Can a stuck turbocharger wastegate on a Cummins 3.9L cause oil to vent through exhaust gases? :(
13 years 2 months before #37845 by manual-mecanica
Manual-mechanics response on the Ford 4000
Hello, the valve only closes the exhaust gas pass so that the turbo does not continue and the oil passage if it can go through the retain from the escape side of the same turbo but it is already another internal problem of the turbo greetings
