Electric fault
13 years 1 month before #37733 by manual-mecanica
ELECTRIC FAILURE PUBLISHED BY MANUAL-MECANICA
: Dry: I do not get current to the piston 1 and 3 coil of a Terios 2003 truck
13 years 1 month before #37737 by manual-mecanica
Manual-Mecanica Response on the subject Electric Failure
You checked the fuses, the ECM signal arrives to the coil, the coil (primary and secondary coil resistance) has resistance) .....
13 years 1 month before #37747 by manual-mecanica
Check resistance in the coil and check if current reaches the + and if the signal of - the ECM, check wiring ...: D: D: D: D: D: D: D: D: D:
13 years 1 month before #37761 by manual-mecanica
I bridge the feeding cable with that of the 2 if it is only the food to cut, but why do you say coil 1y3 do you have 4 independent coils?
