Corsa electrical problem
13 years 1 month before #37694 by manual-mecanica
Corsa Electric Problem Published by Manual-Mecanica
I have a problem in the lights of the patent and reverse that they do not turn on, and if I leave the reverse and light the lights the motor contact opens not being the key put would like some advice thanks beforehand.
13 years 1 month before #37698 by manual-mecanica
Manual-Mecanica Response on the Electric Problem Theme Corsa
AVESES The interruptor in the box that acts the reverse lus breaks and mass
13 years 1 month before #37699 by manual-mecanica
Look if the car has the playful engine and if it is not tightening the cables of the vulvo behind or if the clutch orquitable is not touching the cables.
13 years 1 month before #37709 by manual-mecanica
The currents are being crushed to take it to an electric because they can be baria different things, and it can be worse if you try without knowing.
