Range Rover 93 does not start
13 years 1 month before #37601 by manual-mecanica
Range Rover 93 does not start published by Manual-Mecanica
The distribution chain locked him was changed and everything put on time as the manual says, medium comprehensive is perfect looks good but still changes rotor and module igntion comes good fuel to try to start but nothing that I have more to check and how? Thank you I hope and you can help me
13 years 1 month before #37616 by manual-mecanica
Manual-Mecanica response on the Range Rover 93 theme does not start
So your question is not clear explain to me a little more, was the chain out of point? Walking and stopped? How did the problem start? I await your clarification so I can help you thanks byby gaby
13 years 1 month before #37618 by manual-mecanica
If I was out. The girdle, check and the address pump began to sound very strong and brake the blow engine I think that made the chain now the time is fine but it does not start
13 years 1 month before #37623 by manual-mecanica
Hello, if you want to talk more quickly with me, look for me on Facebook or pass me your
good I will try to solve the problem
the
news I have to give you is not very good
if you come and stop
when you disassembled you found the distribution out of the point
you have bent valve that I is wrong because that is time and silver luck gaby
13 years 1 month before #37624 by manual-mecanica
Well, look for me like And not check the compression and they all gave more than 150
