My alternator generates 0.6 and when I accelerate 1 volt.?
12 years 11 months before #37540 by manual-mecanica
I have an alternator of the Nissan Ga15 engine that does not work and when measuring it, it generates 0.6 and accelerating 1.0 volts that can be someone can tell me that it can be t_t ...
12 years 11 months before #37565 by manual-mecanica
Manual-Mecanica response on the subject My alternator generates 0.6 and when I accelerate 1 volt.?
Obviously your alternator is not loading, you must take it out and verify if they are your coal or west plate.
12 years 11 months before #37570 by manual-mecanica
First Czech coals, regulatory plate and diodes plaque if everything is ok then it is enfobinated but if it is the GA15 buy the alternator is cheap, if the enbobinado is bad
12 years 11 months before #37575 by manual-mecanica
Naaa already tried the stator rotor and diodes are ok ... I have a slight doubt of the voltage regulator ...
12 years 10 months before #37591 by manual-mecanica
Friend it seems to me that when you tested the alternator it was not connected to the battery, so that they have to be induced with a cable that takes you current by giving contact to the key
