independent installation of a thermoswith
12 years 9 months before - 12 years 9 months before #37391 by manual-mecanica
Independent installation of a thermoswith published by Manual-Mecanica
Hello everyone, I want to install a Thermoswith to a mitsubishi lancer cedia so that the fan works independently, someone could tell me
how to do it that, should I use? And
what should I take into account?
Please help: Dry:
another question: what kind of thermoswitch use and that official voltage please help ....
Latest edition: 12 years 9 months before by .
12 years 9 months before #37404 by manual-mecanica
Manual-Mecanica Answer on the theme independent installation of a thermoswith
Hello Isachdd.
It seems that you have a problem with the engine thermostat, it is not convenient to reform the cooling mechanism because if it is fine, it assures you the correct range of working temperature. Before the reform it would be good to try to correct the problem. Luck.
Miguel
12 years 9 months before #37406 by manual-mecanica
The thermostat is in good condition will be at its temperature and the problem attempts, but the problem persists. The problem is the following:
when you put the key in "ON" the fan immediately begins to turn, so I wanted to make an independent adaptation, so that the fan works in its time. My question is still how do I adapt?
12 years 9 months before #37414 by manual-mecanica
The installation is not idfic of doing but you must leave it well hidden so that Feito does not see the car, I tell you because it is almost a sacrilege for a lance Amps, female terminals about 10, and boys terminals, about 10 to have. Now an important point if you have a temperature bulb replaced it if you do not have it then a tube of the measurement of the upper hose measure Temperature, ok Once this is eaten with the electrical installation.
You put a cable from the battery positvo to line 30 of the relay, in this line you install the fuse holder and the fuse, then line 86 of the relay you throw it into a positive contact sheet of contact sheet, the 85 line is one of the terminals of the bulb you installed and the other terminal of the bulb Va Hasia dietta, either chassis or battery you see you, the line 87 of the line 87 Relay is going the positive of the electrventilator and the negative cable of the same goes has direct land, and already, nothing from the other world.
www.velocitymaxima.com/forum/showthread.php?t=142804
In that address is the drawing so you don't miss luck.
12 years 9 months before #37419 by manual-mecanica
Thanks for the datazo now my query is as follows: what damage could cause you to the operation of the engine
