Problem with Kia
12 years 9 months before #37322 by manual-mecanica
KIA problem posted by Manual-Mecanica
Hello friends, it turns out that I have a problem with a kia river of the year 2002 16 gasoline valves it turns Electronic, I don't know what else to do it please if you can help me, I thank you for a lot thanks
12 years 9 months before #37338 by manual-mecanica
Manual-Mecanica Answer on the problem with Kia
Try taking the thermostat, you have seen what happens, a question when the vehicle stops then starts normal or costs it
12 years 9 months before #37359 by manual-mecanica
Thank you Kikemec once I do not start, it starts, starts but as if it were out of point to very few revolutions until you get completely after you leave it for a while about half an hour and start again until the same thing happens again, thank you very much.
12 years 9 months before #37380 by manual-mecanica
You checked the precion but when it presents the fault, it could be the problem of the fuel pump, as well as one one one one kia AVELLA arrived with the same failure, and in the meantime search found that when the electro -ventilator worked and worked the current load the current load was a lot, and I interrupt the earth you have the fuel pump put a direct land and it was solved, of course in another occasion I pass it with Kia trembled on low and tended to stand when it is working for a while and in that was a problem of ijectors.
12 years 9 months before #37461 by manual-mecanica
Thanks Kikemec I will do that to have such.
