Turbo Toledo
17 years 5 months before #3697 by manual-mecanica
Turbo Toledo published by Manual-Mecanica
Greetings the first, I have a problem with the turbo.
I have already changed filters and flow but
I put the car at 90-100 and how much it does not go,
I turn off and work perfect again, I told me that it is from the solenoid but I do not know where it is, because you could send me a serious scheme.
Thanks in advance. : S
17 years 5 months before #3699 by manual-mecanica
Manual-Mecanica Answer on the Re: Turbo Toledo
What car is it to know what you can be diesel or gasoline greetings
17 years 5 months before #3704 by manual-mecanica
Hello, check if any depression hose has been disconnected or in the turbo has a valve that is called West Gate and it is activated by depression (it opens) sees if it is the member disconnected and if you do not check all the hoses that go to the two activists of activate that always tend to break some.- Check and let me know greetings.
