Problems with Opel Corsa Sport 95 1400cc 16VV
12 years 10 months before #37066 by manual-mecanica
Problems with Opel Corsa Sport 95 1400cc 16VV published by Manual-Mecanica
Good I have an Opel Corsa Sport 95 1400cc 16VV to which the valves were changed for having burst the belt but now it does not start, it does not reach the gasoline pump or the ignition coil I thank you in advance for your help.
12 years 10 months before #37069 by manual-mecanica
Manual-Mecanica Answer on the subject Problems with Opel Corsa Sport 95 1400cc 16VV
Hello, a question did not put by chance a starter charger?
12 years 10 months before #37075 by manual-mecanica
If you already checked the fuses, check the ground cavles that are mounted to the snack of the admission air hose usually forget to connect them.
12 years 10 months before #37088 by manual-mecanica
Thank you very much for your help I will review them with the mechanic to see if it connected them well. I think something had to have left disconnected when changing the valves.
12 years 10 months before #37089 by manual-mecanica
Thank you what the mechanic told me was that they brought him out or put another battery since the one was without load.
