Failure in the direction of Peugeot Partner
13 years 4 months before #37044 by manual-mecanica
Peugeot Partner Steering Failure - Posted by manual-mecanica
The direction of my partner is getting hard, does not return to its position with the same softness as before, which are the possible dysgnoses, which should I review?
13 years 4 months before #37057 by manual-mecanica
Manual-mechanics response on the topic of Peugeot Partner Steering Failure
First of all, check the hydraulic pump oil level, then the pump itself, and finally the terminal and axial components of the steering. If everything is okay, align the vehicle, and if it doesn't improve, it's the rack and pinion.
13 years 4 months before #37061 by manual-mecanica
Good, very good recommendations. I'd like to add that it could be a bolt in the rack and pinion, allowing oil to pass to the other side of the cylinder and preventing it from returning to its original position.
Alternatively, the control valve seals might be leaking.
Well, I hope this helps.
13 years 3 months before #37230 by manual-mecanica
Thank you very much for your suggestions, already check the level and I think the matter if it merits mechanically reviewing the entire system, greetings! I will tell you what happened.
