I need Fiat Fiorino 1.5ie data
13 years 2 months before #36985 by manual-mecanica
I need Fiat Fiorino 1.5ie data published by Manual-Mecanica
Greetings to all here.
I have a problem with a Fiat Fiorino 1.5ie year 96. The symptoms: speaker, and sucks when accelerating sharply, does not respond quickly. I want to check the sensors, but I need the check data. If someone could facilitate it or give some indication of failure.
Thank you
13 years 2 months before #36994 by manual-mecanica
Manual-Mecanica Answer on the subject I need Fiat Fiorino 1.5IE
When spending is usually regulation of valves those vehicles bring chauchas. The other is sucking and it is with Czech coils the status of spark plug wires, and the state of the air filter ahy a hose that is from the air flow mass meter is black or green also affects and you have to accelerate a lot to do well.
13 years 2 months before - 13 years 2 months before #37005 by manual-mecanica
1 That every thousand thanks Kikemec, as always successful in your answers.
I tell you, it has taque sounds, checking there are slacks. Check the coil. The primary resistance gave me a value 0.1 OHMS (Autodata 0.4-0.5Ohms) Resistance 2 is within the ranges. Now what you tell me about the air flow mass meter. As much as eh sought, I can't find something similar, now the butterfly body is a suppressed manguerite with a screw. Is that? Where that meter should be found. I attach some photos
greetings
Latest edition: 13 years 2 months before by .
13 years 2 months before #37010 by manual-mecanica
It is the monkey point so it is not so terrible to clean the body of admission or tbi as you call and clean the monoainctor for better results and tests to walk much better.
13 years 2 months before #37053 by manual-mecanica
Check sensors and calibration, change of spark plugs, cables, oil, oil filter, benzine and air. Body cleaning admission, and injector. Adjust valve slacks, adjust tuning and everything perfect. Pretty conforms to be the 1 time I see a Fiorino. And thanks to Kikemec for his help.
