Honda Accord 93 STD Ignition failure ??????
13 years 4 months before #36978 by manual-mecanica
I have a 1993 Honda Accord with a
manual transmission. It starts, I drive it for a while, turn it off, and when I try to start it again, it won't start until after about 10 minutes. It doesn't happen often. It was an automatic, and I converted it to a manual. I don't know if that's related, but it had the same problem when it was automatic.
What could it be?
13 years 4 months before #36998 by manual-mecanica
Manual-mechanical response on the topic of HONDA ACCORD 93 STD IGNITION FAILURE????
My friend, in these cases the range of possible causes is large, but it would be helpful if, when it doesn't start, you check if it has spark or if it's not getting fuel. That way we can narrow down the search. I've seen this problem caused by faulty ignition coils, fuel pumps, and ignition modules.
