Transmission problem
13 years 2 months before #36902 by manual-mecanica
Manual-Mecanica Response on the problem with transmission
MFPRSKA wrote: good
forgiveness for the delay but I was pfreguido with several transmitionists and they all gave me the same answer
that this breathtaker is closed and that you have to cover it because in high speeds you will sympre it will throw oil and tell your transmitionist that it is not idiotic that this transmission does not have over-drive
Ok, aaaaaaaaaaaa! So I have to cover it, the truth is that I feel that the transmission works well and I think I just wanted to lower the transmission receivable, when the vent will I cause to throw oil on the other hand? Or it has another one that I have seen.
13 years 2 months before #36903 by manual-mecanica
Good
if you have it to cover the transmission to replace by the good oil measurement tube,
it would be everything to do and noz you comment that it was you
13 years 2 months before #36911 by manual-mecanica
Ok, thanks I try and tell you how it went, I just have to have a pretext to leave with the truck: EVIL: .
Thanks and I will have them aware.
