Citroenxara Fair
13 years 4 months before #36761 by manual-mecanica
Manual-mechanics response on the topic of Citroen Xsara breakdown
Does anyone suggest anything else?
13 years 4 months before #36826 by manual-mecanica
Try cleaning the idle air control valve. If you can, take a picture so I can see which valve is better! If that doesn't work, I'll continue helping you once I know exactly which valve you have! Cheers!
13 years 4 months before #36900 by manual-mecanica
I hope my opinion helps you. I had the same problem with my car, and they just cleaned the throttle body, the MAF sensor, the IAC valve, and the TPS (throttle position sensor), and they replaced the PCV valve, and the problem was solved
