Ford Focus Year 2001 1.8TDDI
13 years 4 months before #36660 by manual-mecanica
2001 Ford Focus 1.8TDDI. Published by manual-mecanica
Hello good morning I would like to know what it is and where the start of starting a Ford Focus 1.8 Tddi of 2001 is to see if anyone knows where it is or what is the reference
13 years 4 months before #36664 by manual-mecanica
Manual-mechanics response on the topic Re: FORD FOCUS YEAR 2001 1.8TDDI
Hi nachete001, the relay is number 17, black in color. It's located in the relay and fuse box in the engine compartment. I hope this helps. Cheers...
13 years 4 months before #36682 by manual-mecanica
Thank you very much podasetos71, I'm sure it will be helpful. I'll see if I can get it checked out at the workshop tomorrow, Monday. Thanks
13 years 4 months before #36684 by manual-mecanica
Hi again nachete001, if your problem is that the starter motor won't turn, it's possible it's due to a water leak that these cars have in the engine coolant thermostat housing. The water drips directly onto the starter motor and damages it. Cheers...
13 years 4 months before #36693 by manual-mecanica
No, the problem is that I changed the fuel pump, and after verifying that the pump is the same with the same part number, it's not giving me a start signal. Also, the diagnostic tool won't let me access the engine compartment; the immobilizer light is flashing. I've asked around, and they told me it was the relay, that they fail in all cars, and that's why the diagnostic tool won't let me access it and it's not giving me a start signal. But the person who told me that didn't know exactly which relay it was, that's why I'm asking
