Front / right brake problem
13 years 3 months before #36655 by manual-mecanica
Front / right brake problem published by Manual-Mecanica
Hello I have a problem with the brakes of my car, a few days ago I changed my car, purge the brakes and all good but the front / right brake, I started to grind and make a noise as if you wanted to loc To go out when I started accelerating and when the speed increases it no longer feels and is no longer heard as if it were going to work, my car is a 97` 2.0 4 pts scor. Automatic
suede thank you very much, I hope you can help me.
13 years 3 months before - 13 years 3 months before #36657 by manual-mecanica
Manual-Mecanica response on the Re: Front / right brake problem
hello. That wheel you say wants to tie (stop more than the other), you have to change the embol
Latest edition: 13 years 3 months before by .
13 years 3 months before #36658 by manual-mecanica
Thank you Chido_dovis for answering my question, check the embolo to change it or see what problem you have, I hope that the problem is nothing else.
13 years 3 months before #36663 by manual-mecanica
Hello Luis_ $, the same thing happened to you a couple of years ago. The right front wheel was stopped when the brake pads changed, after breaking my head to see what happened, I realized that the problem was that when placing the pills (tiles) they threw the clamp out and played on the Rueda disc (tire). Check that the wheel (tire) does not have friction marks produced by the clamp. I hope the comment is served, Salu2 ...
13 years 3 months before #36668 by manual-mecanica
Check the hose and displaces them of clamps
