Electroventillator Ford Party 2006 does not turn on
13 years 4 months before #36585 by manual-mecanica
Please I need if someone has the electrical diagram of Ford Fiesta 2006 or any idea of ​​the problem because it does not turn on any speed
13 years 4 months before #36895 by manual-mecanica
Manual-mechanics response regarding the topic: Ford Fiesta 2006 electric fan not turning on
The points you should check are: the temperature sensor is in good condition (disconnect it, and if the fans turn on, that's the problem).
Check the fuse next to your battery (it's most likely blown; you'll need to replace or solder it).
Check the resistor at the base of the fans (you'll have to remove the fan to check if the contact is open).
Finally, check the fan relays located next to the fan near the headlight on the battery side; the problem might be there. Good luck.
13 years 4 months before #36943 by manual-mecanica
In a 2006 Fiesta with a 1.6 Rocam engine, you should first check its fuses, then the relays involved in the ignition of the first and second speeds, and if all that is okay, check the power wiring to the relays from the fan motor. If all that is OK, you probably have problems with the ECU since the ignition signal to the relays is not emitted directly by a bulb (as in classic cooling systems), but rather the ECU intervenes in that management.
