Endiague problem
13 years 3 months before #36700 by manual-mecanica
Manual-Mecanica Answer on the Re: problem with intoxication
: S I am not sure because the Embreague pedal always stays above that the brake pedal level if I was broken I think the pedal should be below and another of the things is quite hard the Embreague I will also try changing the cable.
13 years 2 months before #36752 by manual-mecanica
You changed the press for casolity, it may be this of the fault or that the steering wheel is crooked.
13 years 2 months before #36768 by manual-mecanica
Manual-Mecanica response on the problem with the intoxication
Look check may well be a problem of the plaque cams if it has
either the plate diaphragm or if it cannot be that the lever that acts to the thrust ruleman is broken or folded
13 years 2 months before #36775 by manual-mecanica
Hello friend ,,,, I think that the cable is artly reviewed .... Check the support bases of the same, or the place where it rests on the wall of fire and in the box, check that the nail goes on the pedal is not breaking all the pedal mechanism must be firm and if it is further knocked down the box. And ...
13 years 2 months before #36805 by manual-mecanica
Tomorrow I tell you what happens will change the cable and we'll see what happens : Pinch:
