Nissan Sentra B14 engine failure, motor1.6. 16 Val
13 years 1 week before - 13 years 1 week before #36546 by manual-mecanica
Good morning, the engine failure is as follows, every time I turn on the engine it gives a sound as if it were a diesel engine and the 8 secure is removed after being on. The engine was new in December (all) 2011. The oil is complete uses semi-synthetic castrol 15W-40.
Year of the 1998 vehicle
What will that sound? Please
greetings
that have a good day
13 years 1 week before #36555 by manual-mecanica
I also need the Nissan Sentra B14, Motor1.6 workshop manual. 16 valves.
greetings
that have a good day [/quote]
13 years 1 week before #36556 by manual-mecanica
Three little things changed all shells in the crankshaft, taquets and oil pump
13 years 1 week before #36558 by manual-mecanica
Oil as a minimum should be a 10W40 not a 15W40 The oil filter we are sure that it is sometimes you can go but it is not yours and the pressure deviation valve takes longer to act, in addition the sound is as if it were without oil or as if it were too advanced, there are so many things that can be
13 years 1 week before #36574 by manual-mecanica
Good morning friend I made the engine I bought all your pieces in its entirety. With respect to the oil, I did not know that it could be placed 10W-40, the time is full advanced.
I will take your recommendation into account to see how it goes.
Thank you very much
that I have a good day
greetings
