Failure sensors and check Engine does not turn on
13 years 3 months before #36328 by manual-mecanica
Greetings to all here.
Which may be passing when igniting is turned on by the Normal Check Engine witness. There are bad sensors but it detects them, even disconnecting others in good condition. Any sensor that disconnects the check Engine does not turn on. It is a Nissan Sentra 95
13 years 3 months before #36329 by manual-mecanica
If you could describe the engine failure, would it be easier, why is the question?
13 years 3 months before #36330 by manual-mecanica
Cut cable neutral sensor, bad coolant temperature sensor, try to make failures to see if the check was caught and nothing. It is as if everything was fine.
And reality is not so. Very unstable slowdown.
13 years 3 months before #36331 by manual-mecanica
Check the injectors, distributor lid and spark plug wires
that is not detected by the computer
13 years 3 months before #36332 by manual-mecanica
Ok. Having if I do not explain well, my question is going to be independent if there are sensors that detects or not as it can happen. I think there must be a fault avizo when intentionally or does not disconnect or fail any sensor such as I hize (MAF, TPS, TPR, O2 sensor) In no case does the signal turn on. Could the failure be in ECU?
