Hello dear companions, I am new in this social network, I subscribed because I have a problem with my Stratus is a 99 2.4l normal automatic (without turbo) model, and it turns out that it has the next fault and slow or slow occasions goes out or if I handle at a constant speed of 110 - 120 km/h after 20 min, it seems that there is a cut of energy a red focus is turned on in the board It engages and turns off the car unless the neutral is quickly target before it turns off again and so on does it every 20 min or sometimes it takes longer to make the failure.
I already changed the crankshaft sensor, the gasoline pump, they already washed the low gear valve, the truth is no longer what I do, I ask them for favor if someone could solve their problem shares the solution thank you !!!!!
