Spark plugs with Hollin
17 years 4 months before #3622 by manual-mecanica
Hollin spark plugs published by Manual-Mecanica
How, I have a 128 1300 with APA IAVA and a Weber 32-34 and I recently put on Electronic Regatta. The problem that the car was fine until it made an electrical fault, check and were the spark plugs.
17 years 3 months before #3623 by manual-mecanica
Manual-Mecanica Answer on the Re: Spark plugs with Hollin
Check the spark plug wires and see the carburetor gilet that may be that some covered and does not make you proper combustion and dirty the spark plugs for the fuel non-burned, or it may be that the carburetor is not well graduated and does not do well the mixture of air-gasoline.-
17 years 3 months before #3627 by manual-mecanica
It has 8mm marsh cables. They have 4 months of use. to carburetor changed gum because according to what I read here I had bigger. Anyway very grateful
17 years 3 months before #3628 by manual-mecanica
17 years 3 months before #3647 by manual-mecanica
Test with higher thermal rank spark plugs so that you have a better burning since you increased food and spark but you need to increase heat in the camera.
