Celic ignition problems 94
13 years 3 months before #36198 by manual-mecanica
Celica 94 ignition problems published by Manual-Mecanica
Hello friends I have problems with my 1994 Toyota Celica When trying to turn it on or cut the current of the injectors and keeps out towards the spark plugs. There is a poor spark and only the engine turns. I really appreciate your answers
13 years 3 months before #36238 by manual-mecanica
Manual-Mecanica Response on the Re: Celic ignition problems 94
Check the ignition circuit, there must be 12 volts in coil and injectors, you can also check the key switch.
13 years 3 months before #36293 by manual-mecanica
Thank you Richard, in any case, am I far from having computer problems?
13 years 3 months before #36294 by manual-mecanica
You have to review the signal of the camshaft and crankshaft position sensor, if there is frequency in them because it is nothing more to feed the ignition circuit, you may have problems in the electrical installation. Did you already check the 12 volts in coil and injectors?
12 years 11 months before #38752 by manual-mecanica
Richardtz! I thank you, mine has no camshaft position or crankshaft position, I changed 2 computer capacitors that were emptied, and I started and I walked through 2 days and from there he died again, with the same problem, that the engine turns, there is a spark, gasoline pressure, but nothing (it does not start), the injectors also walk well and so far.
